The following updates have been made in Revision AB of this guide.
Updates | Description |
gre (show command) |
Added the concentrator command. This command allows you to configure a GRE concentrator profile which enables a ExtremeWireless WiNG controller to operate as a terminator for GRE tunnels configured on ExtremeCloud IQ managed Universal APs running IQ Engine OS. GRE concentrator supports up to 1000 GRE tunnel terminations. |
Added the smart-sensor-status-timer command. This command is associated with smart-rf-policy commands, and works in conjunction with the smart-sensor command. When the configured timer interval expires, the RF Domain Manager checks the status of radio sensors. If the status of the sensors is Off, recalibration for the smart-sensor feature is triggered. |
The following updates have been made in Revision AA of this guide.
Update | Description |
iot-device-type-imagotag | Updated the show iot-device-type-imagotag status command to include Claim ID in the status output. The Claim ID is a 16-digit hash-code that needs to be passed to SES-imagotag V:Cloud database after USB-Dongle FW update. |
aggregation | Corrections have been made to this interface-config-radio-instance command syntax. |
